Seeming Bug
cyrus_costa541cyrus_costa541 Member Posts: 56 EDU
Often when I am working on a very complicated sketch the program seems to become confused and says my sketch has failed when in fact it hasn't. For example, it said my sketch had failed when I turned a regular line into a construction line. Another example, I attached a curve to another line and made the two tangent. The line was already defined however the curve was completely undefined and had zero other constraints. There are many more examples of this I can share but it most often happens when a sketch of mine has a lot of lines, is fully defined and I add something to it.
