WHATS WRONG WITH YOUR APP
Okay so when I create a document, and I press sketch, I create thing (I don't know what its called). So when I press objects to create, I expect them to show up on the document. Ever since two days ago, I couldn't access the shapes, or put the shapes on the page. First I can't even draw a sketch and would not work….. yall need to fix your app because its not giving….
Working fine for me. Screenshot? Have you selected a sketch plane?
3 -
I know its not the best mobile interface in the world but...perhaps not the best starting post to get a helpful response.
Have you been using the app successfully before two days ago or are you new to onshape and/ or parametric modeling?
If you have been using the app successfully previously can you give a little more detail to your problem?
If you are new to Onshape can I recommend the self paced tutorials?
Engineering textbook: https://hwh.stephenteacher.com/txtbook.html0 -
hell yeah brother man
