Asymmetric Revolve?
brad_simmonsbrad_simmons Member Posts: 8 PRO
edited September 2024 in Community Support
Part of my problem is I'm pretty sure I'm going about this wrong but I'm not sure what I need to search for to get on the right track.
I'm trying to create a ribbed cylinder (soft plastic fishing lure if you're familiar) but instead of having the ribs symmetric all the way around, I want them taller on one "side" and then shorter on the other and the "revolve" to taper to connect these. I was also hoping to do the linear pattern along the spline on the top and bottom but I'm not seeing a way to do that aside from removing constraints and then making each point coincident with the spline. Even then, when doing a revolve or a couple, it'll still have issues.
I also tried doing the smaller revolve and then a second revolve of the taller side with the revolve axis shifted up a little (construction on the left "nose"). This kind of works but it still doesn't blend well on every rib. Ribs with smaller diameters start to get a hump on them. Edit: I should also mention that this is with the top ribs at 10mm tall and bottom at 8mm as seen in the drawing. If I want to have a greater difference in heights, this will obviously get worse.
So, can someone please point me in what I assume is a very simple process to achieve this that apparently I'm too thick headed to wrap my head around? I appreciate any input on this.
https://cad.onshape.com/documents/faea1abb79fc4793c35757d8/w/aada43378dbe64ef9713b963/e/03e4252b308656dd1264e33a?renderMode=0&uiState=66e8dfa38d83696558221db7
