Merging pipes
Hello,
I've been stuck on this for a while, tried different techniques and this is the best version so far. I'm trying to get the pipes to merge, right now theres a hole where the 3 pipes meet and they collide on the inside. Would love some advice!
https://cad.onshape.com/documents/9edada587b000a13e9fcac62/w/501e322d1d83b8dc87412164/e/95dc10e8eb14e239a23087be?renderMode=0&uiState=6710ffa33a459e5d1dc23088
  • rick_randallrick_randall Member Posts: 418 ✭✭✭
    edited October 2024 Answer ✓
    @maurice_bierman
    You may want to look into the "frame"command. Here is a link to a sample of your type of part (not to scale)
    https://cad.onshape.com/documents/27563cde1fcca66e459c5839/w/3f3593a55c20c2efeee84757/e/251430f25978a8e7fea2469a
    Using frames will require some "getting acquainted time", but I think you can see it's a pretty light workflow (do a section view on the top plane). There are probably half a dozen ways to model this part, this is just one idea. You could just sweep a solid, then shell.
  • MDesignMDesign Member Posts: 1,381 PRO
    If you need to have it at that angle. then I suggest a sketch plane on that construction line. like this and redefine sketch 3 to use that new plane. like this.
  • robert_scott_jr_robert_scott_jr_ Member Posts: 788 ✭✭✭
    Another (of MANY) approach. - Scotty
    Rietje - Copy | Rietje 2 (onshape.com)
  • glen_dewsburyglen_dewsbury Member Posts: 1,314 PRO
    Here's another that turns out pretty simple. My thought also was frames as soon as I looked at this. Ended up trimming the joints as 3 pieces because I was thinking of tubes, UUHH!! When I clicked that it's 3D print as one part the method got a lot simpler with offset faces and a thicken still using frames for ease.
    Y-pipe
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,724 PRO
    Maybe a bit late to the party but doesn't this do what you want?
    I only needed one sketch and 3 features using the profile sweep but you would only have needed one more sketch to do with regular sweeps.
    These kind of things are always easier to make solid first and hollow out with a shell at the end.
    https://cad.onshape.com/documents/22703e5b5dc39367a01b7b2c/w/d69a51eecd9edba4354da160/e/60275a2d71bbdef433907c83?renderMode=0&tangentEdgeStyle=1&uiState=671300978da3e86a6524ebb5
    Are you able to clean this angle up? or does it have to be at that angle?
    @maurice_bierman
  • maurice_biermanmaurice_bierman Member Posts: 6
    @MDesign Thanks for your response! No, these angles arent necessary, to be fair with you I made it like this so the two pipes would end up relatively flat, one headache at a time haha.
    Is this to be 3D printed? - Scotty
    @rick_randall Thank you as well!! That model is something I can work with, amazing. Thank you so much for showing me how to use frames in this instance! And yes, this is meant to be 3D-printed :)
    Cheers
    Y-pipe
    Eric
    YES thanks
    @glen_dewsbury
    @eric_pesty
    Maybe late to the party but still very welcome! Thanks for showing me more ways to achieve this, I was really struggling with making pipes, you have given me so much insight in how to solve these dilemmas now, thanks a lot! Love this community!
  • jnewthjnewth Member, OS Professional Posts: 124 PRO
    edited October 2024
    If there is general interest in a 3-way joint creation tool please file an improvement request. I've encountered this a few times from tickets and have tinkered with various custom features to do the job but want to track general interest. @jnewth_onshape
