Update featurescript parameters function using API
guillauem_d
guillauem_d Member Posts: 20 ✭✭
Hello there! 😀
I'm having trouble updating features using the API. I created a simple cube using a FeatureScript function
Now, I'd like to update the cube size using the API.
To do this, I tried using GET /partstudios/d/{did}/w/{wid}/e/{eid}/features to see what the feature payload looks like :
  "features": [
"type": 134,
"typeName": "BTMFeature",
"message": {
"featureType": "myFeature",
"featureId": "F1MLG2LKDU3BAgc_0",
"name": "My Feature 1",
"parameters": [
"type": 147,
"typeName": "BTMParameterQuantity",
"message": {
"units": "",
"value": 0.0,
"expression": "40 mm",
"isInteger": false,
"parameterId": "myLength",
"hasUserCode": false,
"nodeId": "ZFBzFaBd6ORWRpTF"
"suppressed": false,
"namespace": "ea5bb9f50cf0e2008a0791914::mbf9fb36657c1ca6e3a0387dd",
"subFeatures": [],
"returnAfterSubfeatures": false,
"suppressionState": {
"type": 0
"nodeId": "tOEqMN8K4lG+dqq7"
However, when I tried updating the feature by submitting the payload to both:
  • POST /partstudios/d/{did}/w/{wid}/e/{eid}/features/updates
  • POST /partstudios/d/{did}/w/{wid}/e/{eid}/features/featureid/{fid}
It didn't work. I keep encountering errors, and I believe my main issue is related to the btType field—I'm not sure what value to use there.
Any help would be appreciated!
  • Caden_Armstrong
    Caden_Armstrong Member Posts: 468 PRO
    btType is not required, but you are missing some other fields which are required:
    "serializationVersion": "string",
    "sourceMicroversion": "string"
    for custom features i think you also need libraryVersion, but I'm not 100% sure.
    It looks fine otherwise. When the request fails, usually there is an error message included with the response that can help solve theses kinds of issue.
  • guillauem_d
    Thank you for your king help @Caden_Armstrong !
    So I tried this payload
      -d '{
    "feature": {
    "type": 134,
    "message": {
    "parameters": [
    "type": 147,
    "message": {
    "units": "",
    "value": 0.0,
    "isInteger": false,
    "subFeatures": [],
    "type": 0
    "libraryVersion": 2491,
    "serializationVersion": "1.2.7",
    "sourceMicroversion": "8ed582034102bef1fc6bca42"
    I get
    {  "moreInfoUrl": "",  "message": "La fonction ne correspond pas.",  "code": 9999,  "status": 400}
    The message translated in english is "The function does not match".
    I also tried removing libraryVersion with no luck 😓
