trouble removing prung parts
hi,
I am tryin to remove the parts entirely all through the section of the feature named "cony" in feature "shape" but only able to remove two of the prungs from the top. The bottom part too removes just to a point and not even as designed to. Please, can anyone advice on how to properly sort that out? I'll be really grateful. Pleases, find the link below
https://cad.onshape.com/documents/29ac85356a4bf126097575ef/w/dfe5f46f635382fcaa00b253/e/cd22c3a7ecdaefe531c6bcc0?renderMode=0&uiState=6718ced49ef8a72ef66f7496
Kind regards
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,968 PRO
    Edit the Extrude "Shape" feature and set it to symmetric.
  • andrew_brown275
    andrew_brown275 Member Posts: 5 ✭
    Hi @MichaelPascoe
    Thank you for the reply. The symmetric makes the feature highlighted for removal ("shape") red and not cutting through. Not know why that is, even when trying other tools within the Remove tool in extrude
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 955 ✭✭✭
    Hey Andrew. It seems the problem is within the sketch used for the Extrude/Remove feature. The extrude fails when a certain portion of the sketch is selected. Close examination reveals this:
    In your sketch use the Use tool to capture that upper edge of part 1 and then make that vertex of cony intersect with that upper edge. - Scotty
  • andrew_brown275
    Thanks @robert_scott_jr_,
    I'll give that a try.
