How to create explicite equation curve?
I wanna create y=sin(x) curve. How can I achieve this type of explicit equation. Again I still dont understand how to use @mahir 's parametric curve featurescript.
  • mahir
    mahir Member, Developers Posts: 1,324 ✭✭✭✭✭
    edited November 2024
    Set your max parameter to 2*PI. Set X to #t. And for Y enter sin(#t rad).
  • rafael_telgmann
    rafael_telgmann Member Posts: 138 ✭✭✭
    You could project a helix onto a surface, but the better way is to learn how to use the parametric curve FS. If you look at the FS, curve 2 in the example should be easy to manipulate to get a sin(x).
  • md_ar_rahman_dip
    md_ar_rahman_dip Member Posts: 18 EDU
    Thank u @mahir got it perfectly
  • mahir
    no problem 👍🏼
