Can surface cuts be locked so they dont always want to be updated if the block is moved ?
similar to solidworks, when you move the bar down to lock items in the tree.
  • muhammad_tayyab_arif
    muhammad_tayyab_arif Member Posts: 13 ✭
    what you are referring to is called freeze bar in solidworks. I think this feature is not yet present in onshape
