Best fit plane
Jed_Yeiser said:@kdee122 this is possible with featurescript, though a better understanding of what you mean by 'best fit' would be helpful. I wrote this featurescript quickly as a guide.
https://cad.onshape.com/documents/e07586cc7fffdd615af9086d/w/32107f51e26ed66715308556/e/a89ed3bf1988fac1cb746969?renderMode=0&uiState=6674ee6a607f8261b36ef812
This is exactly what i needed!!!! jed thanks for the feature script and I will take a look at the code, made it sound like it was a easy featurescript to write. I need to learn to make or at least modify feature scripts.1
2 -
This is exactly what i needed!!!! jed thanks for the feature script and I will take a look at the code, made it sound like it was a easy featurescript to write. I need to learn to make or at least modify feature scripts.1 -
@kdee122 - it'd be worth checking out this link which I used as a reference. It's the same process as solving for the 'best fit polynomial' (A plane is just an equation, afterall!) using a least squares fit. My code places the plane origin at the 'center of mass' of the points and applies a uniform weight to all points. Depending on how you'd like to define your 'best fit' I could see adding quite a bit of functionality here (weighting by distance from COM, for instance).
All of this said, I can't think of an application where I would WANT to use a plane defined like this. Good luck!0 -
Thank you, that is absolutely what I needed.
I use it as an integral part of building a Part Studio around a 3D scan.
The cloud points are precise, but still slightly imperfect. Using your script, I was able to choose many points and get the absolute best fit. This was a huge time savings and quality improvement from my prior process: choosing a three point plane and then having to go back and deselect/select individual points until I felt I had achieved best fit.
The only thing I wish could be different about using BFPfP is to be able to still see the points when I click "Final". (They all disappear from view, as in the below screenshot)it'd be worth checking out this link which I used as a reference. It's the same process as solving for the 'best fit polynomial' (A plane is just an equation, afterall!) using a least squares fit.
One note of caution is that the LSQ approach to minimizing
zdistance is perhaps suboptimal for the problem. It works well, but a more perfect solution would be to minimize perpendicular distance. This would be more robust when the user is working with points which have little x-y variance.I'm not super familiar with FS, but here's the Matlab code to find the plane which minimizes the perpendicular distance of the points from the plane:
% Assume we have 'userPoints', a 3xN array of user-selected 3D points % Find the mean of each of X, Y, and Z. meanX = mean(userPoints(1,:)); meanY = mean(userPoints(2,:)); meanZ = mean(userPoints(3,:)); % Subtract the mean. Take (unfortunate) advantage of Matlab's implicit % expansion to mix the 3xN matrix with the 3x1 vector mesh_points = userPoints - [meanX; meanY; meanZ]; % Take the SVD [U,S,Vt] = svd(mesh_points); % Find the index of the minimum singular value. Since Matlab returns the % eigenvalue as a matrix, we look only at that matrix's diagonal. [minVal, idx] = min(diag(S)); % Find the left singular value vector which corresponds to this singular % value U(:,idx); % This vector is the normal to the plane, so it's elements [A, B, C] are % the equations for the plane A(x-xMean) + B(y-yMean) + C(z-zMean) = 0;
UPDAET: thanks to @Jed_Yeiser's script I was able to modify my code to use SVD. I published it to the Custom FS list, please let me know if there's any feedback or feature requests.
(In a v2, it would be interesting to try using RANSAC, as in https://math.stackexchange.com/a/4574602/222880.)
OMG. Thank you for this…
. Something I've been searching for. This will help so much with ocd of trying to match up with import scans at least for flat areas.. Now if we can get something similar for non planer surfaces…we'll be cookin'!!
2 -
@Jed_Yeiser or @kenn_sebesta167 Been thinking about this script and I'm wondering if it can be expanded easily to create a flat surface vs a plane as well?
@MDesign can you go into a little more detail? My first thought when I read "flat surface" is a plane, but I'm guessing you mean something other than that.
Sure. flat surface is different than a plane in that a surface is in fact a surface. a plane is just datum from which to reference geometry like a surface or others.
technical term might be planar surface. I suppose.
@MDesign, how about making a sketch on the new plane, and then using the "use" command for the points to define the sketch? That would work for many purposes, I think?
My idea is to skip the whole idea of a sketch all together. and just create a surface (or all three plane, sketch, surface) with 3 or more sides depending on the average shape of the points (4 sides is good enough initially)
I don't think what you're proposing is hard, and at the same time I think it's out of scope for the featurescript I wrote. Worse, I don't have the time to pursue this as a separate feature (I don't even have the time to finish up my other featurescript!).
In the meanwhile, I think that what you're suggesting would be very straightforward to accomplish with points projected from the old surface onto the new plane (via a new sketch), and then you can connect the points to have the desired number of sides.
I suppose it might be a good reason to start learning feature script and possibly a good project to start with after the I get the basics down. Thanks for the feedback. most appreciated and good luck with your other FS. I might have to add that since I do a little 3D printing. Nice one.
1
