FeatureScript Editing Logic: Array Indices Not Updating Properly
Objectives:
I am working on a FeatureScript called "Base Array Numbering", which assigns an incremental index to each element of an array. The indices should always start from 1 and update automatically whenever the user adds or removes elements.
The feature uses:
Editing Logic Function(showLogic) to dynamically recalculate indices.- A
forloop to iterate over the array and assign thearrayPointIndexvalue.
My goal is to ensure:
- At the first execution, indices are correctly set as 1, 2, 3, ....
- When the user adds new elements, the indices continue sequentially.
- If elements are removed, the remaining items are renumbered starting from 1.
The Problem:
Currently, the code works only on the first launch. When I reopen the feature or add new elements:
- Some items receive incorrect indices (often 2 is repeated).
- The numbering logic does not update correctly in the user interface.
Debug Output:
When printing values inside the showLogic function, I can see that indices are being recalculated. However, the interface does not reflect the correct values.
Question for the Community:
Why are the indices not updating properly in the user interface?
Is there something I am missing in my use of Editing Logic and for loops?
How can I ensure that the array indices are reassigned consistently when the feature is reopened or modified?
Any insights, corrections, or suggestions would be greatly appreciated. Thank you in advance for your help! 😊
https://cad.onshape.com/documents/ef57e2c5563e31fd6ab509b6/w/145b578f3abf4613a6c46697/e/0829cf8f973dd60a7caaa61e
I suggest reading the documentation on editing logic. Some useful stuff in there.
if the "isCreating" parameter is omitted, then the editing logic function only runs during creation.
www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications1 -
Yes, Oliver, that’s exactly the goal!
Let me clarify further:Expected Behavior:
- Each item in the array should have a sequential index starting from 1.
- When an item is removed, the remaining items should be renumbered, maintaining the sequence.
- When a new item is added, it should receive the next available index, keeping the sequence intact.
For example:
Item A: Index 1
Item B: Index 2
Item C: Index 3______
After removing Item B:
Item A: Index 1
Item C: Index 2________
After adding Item D:
Item A: Index 1
Item C: Index 2
Item D: Index 3Current Issue:
- The
showLogicfunction recalculates indices correctly only on the first execution. - If I reopen the feature or modify the array, the indices don’t update correctly. Sometimes, the indices repeat or don’t align with the expected sequence.
Do you have any suggestions on how I can reliably renumber the indices whenever the feature is reopened or modified?
Thank you for taking the time to look into this! 😊
To clarify, your goal is?
- Item a: Index 1
- Item B: Index 2 ← Delete
- Item C: Index 3
- Item D: Index 4
Becomes
- Item a: Index 1
- Item C: Index 2
- Item D: Index 3
- Item E: Index 4 ← Add
Correct?
For example:
Item A: Index 1
Item B: Index 2
Item A: Index 1
Item A: Index 1
Item C: Index 2
- The
it's the parameter "isCreating is boolean"
Thanks to allI 🙏
leave code for newbies."Basic structure for array numbering"
import(path : "onshape/std/geometry.fs", version : "1511.0"); annotation { "Feature Type Name" : "Base Array Numbering", "Editing Logic Function" : "showLogic" } export const baseArrayNumbering = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Select Items", "Item name" : "Item", "Item label template" : "Index: #arrayPointIndex" } definition.myVariables is array; for (var variable in definition.myVariables) { annotation { "Name" : "Array Point Index", "UIHint" : UIHint.ALWAYS_HIDDEN } isInteger(variable.arrayPointIndex, POSITIVE_COUNT_BOUNDS); } } { println("My element definition" ~ definition); }); export function showLogic(context is Context, id is Id, oldDefinition is map, definition is map,isCreating is boolean) returns map { println("Number of items counted in showLogic: " ~ size(definition.myVariables)); for (var i = 0; i < size(definition.myVariables); i += 1) { definition.myVariables[i].arrayPointIndex = i + 1; println("Inside function, currentIndex is: " ~ definition.myVariables[i].arrayPointIndex); } return definition; }1
