Problems with second feature studio
marena_richardsonmarena_richardson Member Posts: 20 EDU
I am having a very strange problem. I was playing with a second feature studio, trying to implement the mortise and tenon joint in a different way. Despite the fact that I can add both feature studios and the updated name appears, the "Mortise and Tenon Joint v2" behaves just like the first. It should have different inputs and be completely different. Because this is very hard to describe, here is the link to my document. https://demo-c.dev.onshape.com/documents/f0c35293cb9d46bba5d27022/w/def5fd45ea8c4e3b9b70f1f8/e/b32b453bbd2f456483455763. Any help would be appreciated.
  • marena_richardsonmarena_richardson Member Posts: 20 EDU
    edited October 2015
    If I remove both feature studios, and add Feature Studio 2, then add Feature Studio 1, both "Mortise and Tenon Joint" and "Mortise and Tenon Joint v2" behave like the 2nd one. Very strange.
    Turns out I had changed the display name, but not the variable name. Fixed with updated variable name.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,245 image
    This is our bug -- even with the same internal name, features in different feature studios should be treated as different.
