Custom Feature: Gridfinity Bin & Base Generators
  • michael3424
    michael3424 Member Posts: 783 ✭✭✭✭
    Thanks - those should be useful as I continue organize my shop.
  • patrick_peace
    patrick_peace Member Posts: 2
    Wow this is really great. Thank you for the hard work.
  • brad_hoyt
    brad_hoyt Member Posts: 2
    Very good work.  I am having issues with both the label and curved scoop functionality.  Do they require a certain width and length to work?  This has already been very useful for me.
  • tolga_taskin
    tolga_taskin Member Posts: 2 EDU
    Thats great!
    A dovetail feature for the base would be great!
  • artem_sushchev
    artem_sushchev Member Posts: 2
    Awesome work! Thank you for sharing.
    Pocket style slots for magnets for bins would be a nice thing to have ;)
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,935 PRO
    edited August 2024
    Nice features! Ty for sharing.
    RENDERCAD
  • stanislav_kucharčík
    stanislav_kucharčík Member Posts: 3 EDU
    edited August 2024
    Looks great! Thank you for sharing. Do you plan on expanding features, or do you take feature requests/suggestions?
  • bradley_torrie
    bradley_torrie Member Posts: 1 ✭✭
    I have really enjoyed this generator so far! But I am curious why the generator automatically adds a profile at the back of the base when you select to add a filler space. It would be nice to keep it square all around and only add a space/profile/etc when they are defined.
  • JMartJonesy
    JMartJonesy Member Posts: 4
    I noticed the base filler will create smaller slots on the edge they are added too. Is there a way to also create smaller bin bottom connectors to fit those filler slots? I have a setup that can't fully fit another 42mm section on the edge.
    Just to clarify if I add say 30mm of filler on the left it leaves a new empty base slot. I want to create a bin that can fill that 30mm portion as well.
    Much thanks to anyone that has any ideas.
  • john_robinson677
    john_robinson677 Member Posts: 2
    Great tool! Thank you for making and sharing. You have made my life much easier
  • wai_tsang926
    wai_tsang926 Member Posts: 2
    This is a great piece of work which has saved me hours in creating my own designs!
    I wanted to bring to your attention some observations when I checked out the unofficial "specification" at the link: Gridfinity | The modular, open-source grid storage system for your workshop. I don't know if I am missing something but it looks like your bin base and stacking lip are ever so slightly different from that document. I've highlighted the dimensions which look out to me in the sketch below, which shows a cross section of a base below a bin with stacking lip below another bin. Specifically:
    a) dimension of the 2.4mm wide face of the bin bottom vs 2.1mm in the "spec"
    b) clearance between bin bottom and base is a little larger than the "spec", 0.427mm vs 0.25 (technically I don't think the 0.25 of the "spec" is geometrically possible anyway)
    c) the slope of the stacking lip isn't 45 degrees.
    I reckon these differences are well inside the printing error of most 3d printers anyway, but I thought it would be useful to run this past you in case there is an issue here. As an engineering document, we might as well be accurate, in case it finds application in more precise manufacturing processes.
  • mark_walker972
    mark_walker972 Member Posts: 2
    This is really cool.
    I can see in the example shape there is a half bin, but the configuration doesn't allow for half bins…
    Is there a way to achieve that using the offsets somehow?
    Thanks!
  • peter_haug
    peter_haug Member Posts: 2
    Hi Sheishin, thanks for this tool, I am using V8 now. Perhaps a bug, but it seem to crash when I try to add labels or scoops to partioned bins like this one show below. I'm trying to add labels and scoops on the x axis of these bins:
  • derek_van_allen
    derek_van_allen Member Posts: 6
    Following up on wai_tsang926's post, there's another difference between the current version of this generator and the official gridfinity spec. The corner radiuses on the bins seem to be 8mm instead of the 7.5 in the spec, but this leads to the radiuses all being concentric on the corners of the box so I actually consider it to be an improvement over the original and should be compatible with other files found online.
    I forked the code to try and fix the lip geometry but when I adjusted the dimensions for the top lip geometry it also affected the bottom chamfer details because the logic of the two is tied together. The lip not being 45 degrees is bothering me so I'll continue to mess with the code but it would be nice if the main featurescript were updated to correct this geometry so I don't need to refactor my models.
  • ben_mccammon
    ben_mccammon Member Posts: 2
    This is an awesome generator! Way more user friendly than the Fusion bin generator, since you can actually go back and edit the design. However, the one feature that the F360 generator has that yours is lacking is the ability to remove the bottom 42x42mm grid on bins, making the bottom of the bin flat. Would you be able to add that feature easily?
  • fabien_engels
    fabien_engels Member Posts: 2 EDU
    Could you add a field to set the base size ? It would be nice to be able to set up custom size like on https://gridfinitygenerator.com/en .
    For example, for smaller drawers, I use a base of 32 mm.
    Thank you for your work ! It helps so much ! :)
  • michael_bass
    michael_bass Member Posts: 2 ✭✭
    Thanks for sharing this!
  • christopher_read
    christopher_read Member Posts: 2
    When I open the document and go to the generator tab all I get is a page full of code,
  • igalarzab
    igalarzab Member Posts: 6
    you have to go to your Onshape and add the script by clicking the "Add custom feature" button.
    Just in case it's useful, I made another version of a gridfinity generator that tries to follow more strictly the gridfinity dimensions. You can find it here, also with instructions into how to add it to your workspace:
  • Can we please get an option for clicky labels?
  • NAE
    NAE Member Posts: 9 ✭✭
    Did I miss this somewhere? What about the clips?
  • This is awesome.
    What are the differences between the two files?
  • dane_powell
    dane_powell Member Posts: 2
    The second generator is for a Gridfinity base. The first link is for a Gridfinity bin, which sits in the base. Should be obvious once you click through, but it would be nice if this was called out in the OP.
  • levi_stuckey
    levi_stuckey Member Posts: 3
    Hello, So I have no idea how to work with the feature scripts on onshape, but would it be possible to add lid functionality like what's designed here? I want to add lids to compartment bins in a 1ux1u bin on a larger 4x3u bin for hook storage.
    https://www.printables.com/model/1568646-parametric-lidded-stackable-gridfinity-tray
  • kiran_malladi115
    kiran_malladi115 Member Posts: 2
    Hey @seishin , this is awesome. Been using it as my main way to make bins for my workshop.
    I'm considering "forking" this to spin up a remix that has replaceable labels. I didn't see a license in your FS, so wanted to make sure this was ok with you before I did so! Thanks in advance.
