opBoolean subtraction doc is wrong
marena_richardsonmarena_richardson Member Posts: 20 EDU
The doc says: BooleanOperationType.SUBTRACTION will remove the union of all target bodies from every tool body. In reality it's backwards, the function subtracts tool bodies from target bodies.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    Yes, the documentation is wrong here and the behavior is correct.  Making a note to fix this.
