Printing PDF files
I think I need a little help.
We just started using OnShape last fall. I want my students to be able to print a PDF File
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,262 PRO
    Right click on the drawing tab at the bottom of the screen, and there will be an export option. PDF is the first choice.
  • wayne_sauder
    wayne_sauder Member, csevp Posts: 692 PRO
    Or click the hamburger menu and hit print.
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 991 PRO
    Also, you are going to want to make sure your browser isn't blocking any .onshape.com domains. The drawing print to pdf function uses a browser popup.
  • martin_kopplow
    Take care when printing from the browser. I've seen funny scaling effects recently, when I used a client's Mac to print some drawings. Printing the downloaded PDF yielded much more consistent results.
  • michael3424
    michael3424 Member Posts: 785 ✭✭✭✭
    Sometimes the print driver on the computer is set for custom or fit-to-print, rather than 100" to scale. That can cause unexpected printed results.
