Adding dimensions to an isometric view.
2»
  • Vanbelle_jeroen
    Vanbelle_jeroen Member Posts: 4 ✭
    This is my solution for the problem. a bit tideous but works fine. I measure the stuff i need on the side and then override the dimension in the sheet.
