How to remove a material from a curved surface.
eben_alton
Member Posts: 22 ✭
So I'm designing small container. It has a small groove running around the entire inside surface, Unfortunately I can't seem to figure out how to make the groove on the curved surfaces. Any help would be appreciated.
Here are a couple of ideas.
Here is another method, using move face and boolean. I use this method often for half-lap and/or tongue and groove joints for molded parts. It's quick to model, and very robust when making changes.
Yet another technique. I found this one quite handy for under cuts like part 2.
Lots of ways for this one. All shown are good when selected for the right application.
Perfect, thank you for your help!
