Dimension text location - how to move above dimension line.
geeveemohan
geeveemohan Member Posts: 6
Hi Team,
Is there any way to move the dimension above the dimension line, as shown in the attachment
  • michael3424
    michael3424 Member Posts: 783 ✭✭✭✭
    Attachment seems to be missing...
  • Frankie_Liao
    Frankie_Liao Member Posts: 2 PRO
    I'm looking for the same question.
    Is there any way to move the dimension above the dimension line?
    Another question is how to connect the inspect symbol centerline to the dimension line.
  • geeveemohan
  • glen_dewsbury
    glen_dewsbury Member Posts: 1,363 PRO
    edited September 2023
    When I start with an ISO template the dimension is above the line while ANSI template dimension is in the dimension line.
    Oddly, I couldn't find a way to switch location once the drawing had been started with in the drawing properties.
    The templates I used are the OS defaults.
    Maybe it's too early in the day for me. :(
  • David_Asbill
    David_Asbill Member Posts: 11 ✭✭
    Use ISO drawing templates for your dimension to be displayed above the dimension line.
  • gary_cooper788
    gary_cooper788 Member Posts: 2 EDU
    Where do I find the setting to use or change those ISO defaults? In NZ, students are required to have the dimensions above the line
