Two lofts from the same point
I need an "ah-ha" moment. Im making a splitter pipe and want to make two lofts originating from the same extrude face. Basically make the left look like the loft on the right. Seems very simple but i cant select the same extrude face. Am i using the wrong loft parameters in loft one that is causing this?
Screenshot 2025-09-19 at 9.46.39 AM.png Screenshot 2025-09-19 at 9.53.08 AM.png
  • eric_pesty
    eric_pesty Member, pcbaevp Posts: 2,822 PRO
    I think your issue is that you are using "add" for loft1 so the face you lofted from doesn't exit anymore!
    Switch your first loft to "new" and it should solve your problem.
    Or better yet, just mirror your part after creating loft1!
