I am unable to print a drawing from onshape. It either comes out blank or I get an error message
Sometimes the result is blank with no template and no views. Other times I get the message: "Pop-up windows appear to be blocked. Unblock them to enable printing."
How do I print my drawing?
  • graeme_andersongraeme_anderson Member Posts: 12 PRO
    Printing directly from a browser window probably isn't your best option. Try exporting the drawing as a PDF, and print that.
  • ken_fernalldken_fernalld Member Posts: 4
    Yes, I was unclear that is what I am trying to do. When I look at the PDF is is blank, no views no title block just blank B size paper.
  • Ste_WilsonSte_Wilson Member Posts: 634 EDU
    edited October 2025
    Don't use the browser print option directly. If your viewing your drawing click the three horizontal lines in the top left (hambuger menu) and print. That should open a new tab with a generated pdf.
    On some browsers it may spit out a warning that pop ups have been disabled/blocked.
    If so go to your browsers settings, search for pop in the settings and add the onshape website address to the allow box.
