Improvements to Onshape - October 10, 2025
I get it. It doesn't make sense that way…
The enterprise currently bears the cost of the seats (Full or Light) if you want "outside" help - you need to provide a Full Seat with "Guest" access if you need an external person to do work (create geometry). You can assign a Light guest seat if you only need them to review, export, or even approve Releases (your contractor, customer or vendor could have a light guest seat and be part of the approval chain for Revision control).
Guest access ensures they only have access to documents explicitly shared with them (and nothing else) but they can participate in all design functions, release management and export rules etc.
Having a way to provide access to your data from outside the Enterprise would reduce the cost of seats for the Enterprise - or in some cases just speed up the ability to engage. Procurement cycles can mean that although it's very fast to assign a license to a new person - it can be very slow to buy that license if you don't already have extra ones.
2 -
So you're saying the advantage is you only have to select the variable studio variant once which actually makes sense. I'm glad people can make good use of this then.
Agree!
Moreover, it adds thresholds to my stakeholders and cost for my customers to hire me…
I'm going through this right now, and my customer has already sighed, "I wish i could just e-mail you a file…" that's how complicated Onshape is making this at the moment.6 -
Absolutely agree. This enterprise-enterprise connection is very unfortunate. Does not adress the required use case to work with external contractors at all.
1 -
What happened to the pictures on the right of the sign in screen? Did they get removed? Or is this a bug?
@sebastian_glanzner Trick or Treat….It's the 3 week mark….I am hoping the Onshape house will hand out sheet metal loft for Halloween. :)
2 -
@bryan_lagrange I saw some stuff last commit that seems like it's being worked on, I hope this release is the one where it goes live
2
