opBoolean() with BooleanOperationType.INTERSECTION fails with @opBoolean: BOOLEAN_BAD_INPUT
blackslate
blackslate Member Posts: 18 ✭
Hello Helpful Onshapers!
I want to use opBoolean() to "take a bite" out of a solid model. I imagine that this should be done in two steps:
1. Use BooleanOperationType.INTERSECTION to create a "mouthful" of the target
2. Use BooleanOperationType.SUBTRACTION to remove that mouthful
I then plan to put the body created in step 1 back in the gap created by step 2, so that it can be shown and hidden as needed.
Step 2 is working fine. Step 1 creates the error @opBoolean : BOOLEAN_BAD_INPUT, when using exactly the some definitions map as step 1… except that the "operationType" is different.
The error occurs on line 73 of the Main feature script in this workspace:
https://cad.onshape.com/documents/1776f4d7e0da1375f085688a/w/4a622666db4ebdaef2534d40/e/46830a65962f82e472873711?renderMode=0&uiState=69381ff68808f7bd63038112
Any help will be most appreciated!
James
  • ry_gb
    ry_gb Member, csevp, pcbaevp Posts: 273 PRO
    edited December 2025
    Copied Onshape doc
    It's a bit confusing to understand what you're trying to do without the goal modeled in CAD for us to compare with. However, if I understand correctly, the spineCubes are cubes running diagonally down the "spine" of the pyramid. And you're trying to intersect those with the pyramid. I think you're doing it in a for loop because I tried doing them all at once and that didn't quite work. Is that correct?
    Here's what I saw. Below is the "corrected" code:
    • You're using tools and target for Intersection, which isn't valid. You just need Tools, from what I see in the Standard Library Documentation.
    • Also, in spineId, you need to put the index before the feature name or else you'll get an error.
    • Lastly, I'm not 100% sure you need to use keepTools in your boolean subtract, but I'm not sure what the intent is.
    • Same thing with targetsAndToolsNeedGrouping
      for (var ii = 0; ii < size(spineCubes) ; ii += 1 ) {
            const spineId = id + ii+ "spine";
            const spineCube = qUnion([ spineCubes[ii], pyramid]);
            const options = {
                "tools": spineCube,
                "operationType": BooleanOperationType.INTERSECTION,
                "keepTools": true
    Ramon Yip | glassboard.com
  • jelte_steur_info
    you could consider BooleanOperationType.SUBTRACT_COMPLEMENT if you want to essentially do an interesection but keep the control over tool/target. (because target retains it's identity), and allow multiple tools to intersect with only one target.
    This may make your for loop obsolete
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,165 PRO
    I just cleaned up a community made feature with that trick @jelte_steur_info. I kind of wish that was just the default behavior of intersect
  • jelte_steur_info
    just FYI: I just took the effort to publish the basic boolean feature
  • blackslate
    Thank your @ry_gb for your solution. It works well, even though I do not understand why…
    const spineId = id + "spine" + ii;
    … causes an error when you use…
    … but not when you use:
    "operationType": BooleanOperationType.SUBTRACTION
    To give some context to my question, and to respond to your comment "It's a bit confusing to understand what you're trying to do…"
    For a maths class, I am building a physical demonstration of the formula for a square pyramidal number. My completed demonstration will show that the volume of a stepped pyramid with a base n-squared will be:
    the volume of a smooth pyramid with the same dimensions
    + the sum of all integers from 1 to n
    - n / 3
    The part "sum of all integers from 1 to n" is the total additional volume of the steps, and the part "- n / 3" is where the steps intersect the pyramid — in other words, the little "spine" pyramids that you have helped me to remove from the pyramid itself.
  • ry_gb
    I'm not entirely sure why it worked with Subtraction, but not Intersection.
    I'm kinda new to FeatureScript so I don't entirely understand everything yet, but it looks like from FeatureScript Fundamentals course, they do mention you want to put the index before the string because you can't revisit ID's
    Link to video
