can I import some of my DWG files and work on them?
mike_cunningham587
Member Posts: 2 ✭
You can view them. Onshape uses a plugin from Ares Kudo (i think, not able to check right now) If you want to work on them inside onshape/ without leaving onshape you'll have to pass some money to the ares people.
Engineering textbook: https://hwh.stephenteacher.com/txtbook.html0
