Onshape encountered a problem with your last operation. If the problem persists, please contact supp
  • STEGSTEG Member, User Group Leader Posts: 140 PRO
    Just reload your browser tab, It happens sometimes.
    By the way, your document isn't shared (nor public) so we can't access it.
  • mskeelsmskeels Member Posts: 6
    Hi, @sidrah_qureshi I just ran into this same issue. Were you able to resolve this? I have tried everything but with no success (closing tab, clearing browser history, reopening onshape, etc…) my other OnShape documents are fine. I was trying to change the dimension of a circle.
  • jnewthjnewth Member, OS Professional Posts: 139 PRO
    @mskeels it says “if the problem persists try contacting support.” It sounds like your problem is persisting, so contact support.
