FeatureScript for generating Lattices
preston_stanford
preston_stanford Member Posts: 4 EDU
Hello, is there a feature script for generating volumetric lattices on non-planar parts? lets say, a curved face mask and to still keep some of the underlying structure like that hydesign app?
  • MichaelPascoe
    MichaelPascoe Member Posts: 2,935 PRO
    There may be some, but not that I'm aware of.
    You could pattern the lattice (Here is a 🥬lattice template), then Boolean intersect with the region you want it to stay within.
    The workflow could look like this:
    • Copy mask with the Transform tool
    • Shell the original
    • Derive the lattice template into the studio
    • Linear Pattern the lattice template so that it covers the entire copied part
    • Boolean intersect the patterned lattice part with the copied mask volume.
    • Boolean union the lattice part back to the original mask
    RENDERCAD
  • preston_stanford
    Thank you mate ill give that a try!
