Sketches not fully defined and I... admittedly don't understand constraints yet.
2»
  • MDesignMDesign Member Posts: 1,397 PRO
    Your dimensions must be driving not driven.
  • bruce_pricebruce_price Member Posts: 21
    So all dimensions need to be driving?
  • Ste_WilsonSte_Wilson Member Posts: 622 EDU
    Most dimensions will be driving as you use them to define the shape you want. Occasionly a dimension may be added to show a dimension which is already defined but helps read ability. E.g. The dim from one side to a feature is defined as is the overall length, and this makes sense from a modeling perspective, but you put a driven dimension from the feature to the other edge because it saves having to subtract the driver from the overall length every time.
    Bingo!! All define. Thanks to ya'll for the direction. On to the next step of printing!
