Variable in text does not change in pattern
Hi, I have a variable in a sketch text, when I apply a linear pattern which changes the variable, the text does not change.
Following example:
https://cad.onshape.com/documents/89556755f21cf336a44b60d6/w/7259a717c555919364ce36b4/e/56e92cccab259f192183c6ca?renderMode=0&uiState=6727d2a0acee506bdb3c0c00
I would expect the blocks to have the size written on them, but the text is still the initial value of the variable
