Trouble creating a simple loft with guides
david_dugas
david_dugas Member Posts: 11 ✭
Hi, I am trying to create a simple loft between two opposite side faces of a block. The profiles are rectangles with different depths from the top surface. On the top surface I sketched a couple of guide arcs for the loft to follow. No matter what I try I can only get the top surface of the loft to follow the guides. The bottom surface always follows a straight line between the connection points of the profiles. I must be missing something simple. Any ideas? Thanks.
https://cad.onshape.com/documents/163af253ef97ba2ee4497c9e/w/3ded52a9af1074e98be1bcf4/e/b9bff13f557f2487306723f5?renderMode=0&uiState=698481993dc5a2e4a0e88d96
