Is it possible to use feature script to quickly export mass property values for assemblies?
alex_nikolaev582
Member Posts: 1 ✭
Hi all,
Still learning about feature script but I wanted to know if anyone has had any experience using Feature Script to export/output data (specifically mass property values like mass, center of mass, and moment of inertias) into either the command line or ideally into a txt file for an entire assembly. This action would be the same as manually clicking the mass property feature onto the entire assembly but I'm wondering if there is a method to automate this process and have these values easily exported as matrices/vectors. This would be especially beneficial if it can be done for multiple configurations of an assembly.
EvanReese
Member, Mentor Posts: 2,980 PRO
There are 3 major hurdles:- Custom Features only work in a part studio, not an assembly. You might workaround by making a part studio in context of the assembly, and using the transform tool to copy all parts in place. I don't know of a way to get the materials to go with them though, so they'd have to be assigned all over again in the studio. This would also have to be updated for each config, which isn't desirable. I think this is the biggest challenge
- Features can't access certain metadata as inputs, like part name, or material, because it would be crazy to have a feature change behavior just because you renamed something. You can get those things in custom tables though, so that might be the way to go. Otherwise, you'd need a way to manually assign material densities to each part within the custom feature.
- FS is pretty sandboxed and can't export things. I can think of 3 ways of varying difficulty. (1) printLn() to print it to the notices panel, then copy/paste, (2) create a custom table and export that (this sounds best to be so far), or (3) do it via the API, which is over my head, however, you could probably bypass issues 1 and 2 doing it this way too. If this is going to be a common thing you need, it could be worth learning how!
2
Have there been any developments on this issue in the past few years? It would be very useful for certain applications (like aircraft design) to export all mass properties at an assembly level.
Alternatively, part-level mass and inertia values could be created and stored at the part studio level, and the mass/inertia/position/orientation of those parts exported at the assembly level, so that a transformation could be performed with an external tool.
you could add all of these things as computed part properties, then set up a BoM view that shows them. That could be copy/pasted to a spreadsheet for some calculations to get what you're after. Once the sheet formulas are set up, updating it would be fast. Or these days I guess you could vibe code a whole app that lets you paste the table in directly and does the calcs for you.
