Sheet Metal Cutout Tab
brandon_nasonbrandon_nason Member Posts: 7 ✭✭
edited March 4 in Community Support
Is it possible to "pull" a tab out of a flange? I want the red highlighted sketch to become a tab where it's material is cut out of the yellow outlined flange. I need to use flange instead of a bend because I want onshape to calculate the amount of material I need and bend will "shrink" the outline of the original sketch afaik Example document here:
