sweep twist - Boolean fail
ron_moise
Member Posts: 18 EDU
hello, in my trying to better understand the new additions to onshape i tried the following:
mind someone explain to me why doesn't it work?
It seems that at the same ratio the second oparation fails due to the fact the sides cut each other perfectly.
It was fixed when you would not use the same ratio. like so:2
