Need help with creating a counter sunk hole.
So i know exactly what scew we are using but I don't know where i would go to find the exact dimensions I would need in order to create a flush screw head once it's counter sunk. It would be this screw but different length.
https://www.mscdirect.com/product/details/67560169?rItem=67560169
tell me if this would be correct with my thinking. first off i measured the head to be half inch diameter and i see that it is 82 degree head so id go from the top face with a sketched hole down to a 1/4 hole at 82 degrees? Also if you didnt have a screw to measure how would you know how to draw the counter sinks? Lastly what is the best way to counter sign just use fillet or have two sketch planes and loft to one another? I'll probably answer all of my own questions in the next 5 minutes.
John McConnell - Let's change things.
Saplingstore.com
Saplingstore.com
Saplingstore.com
If you want another angle, you will have to model the hole, from a sketch lying on your desired hole axis, as a Revolve/Solid/Remove
Saplingstore.com
The reason for the VS dimension is to be able to size the countersunk hole (off the bat, and/or without having a physical screw to try) so the head will be flush.
Saplingstore.com
A1 is the virtual outside diameter
A is the actual outside diameter
Thanks you so much that helps being able to see it. I successfully drew and machined the countersink.
Saplingstore.com
