how do I export a drawing to have it cut.
doug_watkins244doug_watkins244 Member Posts: 4
tried the instructions in AI and can't find a "export" tab. Trying to test cut with a plasma table. Im pretty ignorant as far as CAD goes. But I follow instructions pretty good. thx Doug
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 979 PRO
    Right-click the tab and select Export…
  • jnewthjnewth Member, OS Professional Posts: 148 PRO
    A couple notes:
    1. make sure your drawing views are 1:1.
    2. if you use DXF (i assume you are) keep track of the units you are exporting in (inches or mm) and check the size on the machine that the cam software imports with / is using. I cant recall if DXF even encodes its units but Ive hit this often enough and heard enough stories to encourage people to check.
  • doug_watkins244doug_watkins244 Member Posts: 4
    thx for responding . right which tab? pretty much clicked every tab I can find and/or get zero popup menus?
  • shawn_crockershawn_crocker Member, OS Professional Posts: 1,026 PRO
    The drawing tab. Right click on the drawing tab you are currently viewing. If you are actually in a part studio which you are mistakenly calling a drawing here, then you right click on the face of the part you want to export as a dwg/dxf. If your in sheet metal, you can right click on the flat pattern to save it out.
  • robert_stilesrobert_stiles Member Posts: 191 PRO
    Hello, if anyone is interested we are just looking to release this. Which might help solve these and similar problems.
