Is there a way to choose a centermost hole from my pattern?
elijahpekaarelijahpekaar Member Posts: 49 PRO
I have a hole pattern running from the bottom to the top of a panel. The pattern is spaced depending on the panel configuration and wind loads. I need to select the centermost circle of the pattern to create a fixed hole (a hole smaller than the rest)
Is there a way to choose a centermost hole, if the hole is not on center of the panel? Currently, I have a config option where I choose the centermost hole for each panel in the list
