Select chain of sketch entities / Select closed loop
joshua_lee840joshua_lee840 Member Posts: 6 ✭✭
edited May 2021 in Community Support
Hello:
I want to select the highlighted sketch lines pictured below so I can convert them to non-construction lines (with the hotkey Q). In SOLIDWORKs, you could right-click any line segment and choose "Select Chain", which would highlight all the attached sketch entities. I had to manually hunt and peck each line to get this selection; is there a faster way to select all sketch entities of a closed loop?
  • peregrine_churchperegrine_church Member Posts: 7 ✭✭
    I've added this as a feature request you can vote for here: https://forum.onshape.com/discussion/27101
  • EvanReeseEvanReese Member, Mentor Posts: 2,967 PRO
    I voted for it
  • DeXxikDeXxik Member Posts: 3
    Good tutorial. Thanks
  • yd_kimyd_kim Member Posts: 2
    thanks your teaching
