Vertical text box with Horizontal letters ?
dionis_aybar
dionis_aybar Member Posts: 2
Is there a way to have a Vertical text box with horizontal letters, without doing each letter separately?
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 979 EDU
    Adding a return after each letter works.
  • harmon_amakobe
    harmon_amakobe Member Posts: 2
    Haha that's hilariosly effective, thank you!
    As an addition, I found that I had to delete an already created horizontal text feature and create it from scratch in order for return to work in the textbox, editing already existing text didn't take,
  • crawl_warner
    crawl_warner Member Posts: 4
    HI.
    Is it possible to center the letters?
    When I write my text like this, all the letters are left-aligned. (upper and lower case)
    Is there a way to do that?
    Thanks.
    S1mon Member Posts: 4,456 PRO
    edited May 13
    Take a look at @jnewth 's Text feature.
    https://cad.onshape.com/documents/4e187c2b2f7f4974f4e2b612/v/4446c75baffebee73f367acc/e/bd277e26bcfb8e1539b8dd3a
  • crawl_warner
    @S1mon Thank you for your fast response.
    I'm new to on shape and can't open the link.
    I have no permission.Do I need a payed plan for the access?
    Thx
    Sorry, link should work now.
  • crawl_warner
    Tank YouTube.
    The solution is way to simple. in theory, will test it.
    Thx
