Is it possible to dimension the length of an arc of a hyperbola?
edward_pan
Member Posts: 15 ✭✭
I know you can dimension the length of a spline - it might depend on how the hyperbola was drawn. "to this curve" also seems like the dimension was between the curve and something else which can cause issues
1 -
Thank you for your reply! I also come to say that Onshape has added this dimension with the latest update!
