Rounding embossed text
Is there a way to round the bottom of embossed text in a flat surface? Similar to if a round, or even v shaped bit was used to cut text with a cnc. I tried fillet and chamfer, but it takes forever and you can't get far without errors.
Hey Hayden. The use of a Query Variable may make the task less tedious. With it you could select all the inside corner edges that need to be rounded. After the variable is created, the variable can be selected as the 'Entities to fillet' within the Fillet tool. That would also allow you to adjust the fillet of all the entities selected in the variable at one time. It would also allow you to easily add or delete any edges that you may have missed by editing the variable. - Scotty
1 -
You won’t get clean rounded bottoms with fillet/chamfer alone—those tools struggle on complex text edges. A better approach is to use a sweep or revolve cut with a round/V‑shaped profile along the text concoracardcom edges, or apply a draft/loft operation to taper the sides, which mimics the CNC bit effect without constant errors.
