Can you define an area field in the Feature definition
christopher_dziubachristopher_dziuba Member Posts: 124 ✭✭✭
For some reason we have the "AreaBoundSpec" but no ability to implement it the same way as a length paramater in a feature definition. Am I missing something??
  • Caden_ArmstrongCaden_Armstrong Member Posts: 453 PRO
    Currently not supported.
    Your options are either to use a "real" number with assumed units. In your feature you just add the units, and tell the user to give a value in the specific units (like m^2). Or second option, you use an "is anything" type parameter and validate the input in the feature.
    For internally used features I usually go with the first option since everyone at a company typically uses the same units, and it lets you specify a range.
  • joshtargojoshtargo Member Posts: 610 EDU
    Even with isArea?
  • christopher_dziubachristopher_dziuba Member Posts: 124 ✭✭✭
    Looks like it's time for another feature request when I have the energy
