Center of Gravity in Assembly
Ron_van_Dijk
Member Posts: 17 PRO
I would like to add a COG in an assembly.
I did find a script for CG Point, only this is not available in assemblies.
Also the script allows for only 1 body to be added.
You can find COG in mass properties (bottom right corner) it should be available in assemblies. You probably have some parts without materials assigned. If that's not the case could you share a screen shot of what you see when you open mass properties?0
Make a composite part of the parts (bodies) of which you like to have the COG and select that in CG Point.
