Question about grading assignments.
Having watched some of the Onshape webinar/videos for educators they show the ability to mark individual student assignments as "graded" or "needs revision". In my classes I can see assignments as they are submitted by my students, but there are no options available beneath the green "Submitted" button allowing me to do any further marking of these assignments. Is this perhaps because I am using the free "educator" license and not the "Enterprise Education" license? Any guidance would be appreciated as not being able to mark the assignments as graded does reduce the effectiveness of the classroom. Thank you.
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 979 EDU
    The option to mark assignment submissions as "Graded" or "Needs Revision" is available on the free Educator Plan. When you mouse over a green "Submitted" status, you should see a small down arrow. Click that and you'll the options to mark the sumission. If you don't see it, make sure the assignment is not closed. Marking assignments is only available to open assignements. If the assignment is closed, just click the "Replublish assignment" button.
  • nenad_bojcetic
    nenad_bojcetic Member Posts: 17 EDU
    Hi Matt,
    A, point of view. I think that this is ok for OnShape course but it not very good for university curriculum.
    In our case asistent publish assignment to students, assignment is available for limited time in which students have to finish it, then he close it and get further with teaching. After the class he evaluates student's work and write comments and on next class he comments with students what they did good and bad. In this case teacher is not able to grade student's work. If he republish assignment then students that did not meet the time limit can continue and that is not ok.
    Best regards!
    Nenad
