Why is my sketch not fully defined?
Hello all,
I've drawn this sketch and all geometric features are black.
Still, the sketch icon in the feature tree displays the "prohibition" sign that indicates the sketch is not fully defined altogether with the "The sketch is no fully defined" message.
Find the file here: There was an error displaying this embed.
What is missing?
Thanks!
  • glen_dewsbury
    Looking at the picture there may be a couple of blue dots on the end of some lines. Would see to see the document to be sure. can you post a link to a public document?
  • nick_papageorge_dayjob
    nick_papageorge_dayjob Member, csevp Posts: 1,264 PRO
    The link didn't work. (It's a common forum bug). Can you try pasting it again?
  • MDesign
    Its possible that someone could help if you are in edit sketch mode and have contraints turned on and then post a screenshot. Even then it can be difficult to help untill the broken link is fixed to see what's going on. Its impossible to help from the screenshot you have provided so far.
  • Ste_Wilson
    Ste_Wilson Member Posts: 681 EDU
    edited June 19
    It's not the end of the world if your sketch is unconstrained. It makes life easier for future you, and, should make it less liable to breaking in interesting and fun ways if you change things in the sketch.
    Generally…it's unconstrained if you haven't fixed any point to the origin.
    It's unconstrained if any point isn't defined by a dimension horizontally and vertically. This can take the form of constraints/ relationships between sketched geometry.
    If there is any blue on your sketch, click, hold, drag…how does it move? What dimension or constraint would stop that movement?
  • salvador_cañadell_moragas
    salvador_cañadell_moragas Member Posts: 6 ✭
    Hi! Sorry for the delay and thanks for the interest.
    Its my first time publishing in the Onshape forums, so I hope I added de link correctly:
    https://cad.onshape.com/documents/b79168070e214f8bf17af67c/w/0c1fa5addfe6a19bca77b63f/e/db0fa8d020e0bbff8e2d40f2?renderMode=0&uiState=6a420ee37a9db665ff0b5b2d
    Hi! Thanks for all your interest in helping! Sorry for the delay in the answer:
    LINK TO DOCUMENT
    See a couple screenshots:
  • MDesign
    Congrats. Looks like you got it figured out based on the document link.
