how to change the configured property name to the configuration item selected
mspiccione
mspiccione Member Posts: 4 EDU
I'm trying to have the name of the part change within the configured properties panel, and I want the name to be the configured Input list name. for example, I want the name of the gear (listed in the properties name of the configuration prop window) to be the name of the configured item in the configuration panel. So when the type of axle gear is selected in the part studio or assembly configuration menu, it changes the inserted part name. The gear FS already did this to some extent, but everything is labeled spur gear, which isn't helpful.
