Cutlist Value input
steven_harris941
steven_harris941 Member Posts: 3 ✭
What value do you use to add a column in a cutlist for either the name of the frame given in the feature list or the parts list?
  • MichaelPascoe
    edited July 6
    Properties are applied after all the features are run in your tree (part name, material, description, etc)… so the getProperty() function has to be called within edit logic or within a custom table feature.
    Example of how to use getProperty with a custom table: Measure cut list - Custom feature
    And an example of how to modify the frame cutlist feature: Cut list+
    Note that frame data is stored as an attribute on the part not as a property on the part. This is why its able to call the frame data live from the middle of the feature tree. Anything getting the properties will have to manually be refreshed via the user changing something in the features ui (usually a refresh button that the dev puts in there.)
