Part mirroring generating too many sheet metal bends
First time Onshape user (with very limited CAD experience) here encountering a problem.
I've modelled a speaker stand which surprisingly turned out exactly how I envisioned it. However when I enter the 'sheet metal table and flat view' there are more bends than there ought to be.
I designed one foot with a slot running the length and 2 bends and used the mirror tool to create the remaining 3. The original leg generates 2 bends in the sheet metal table as expected but the mirrored legs generate 4 each for a total of 14 bends when there should only be 8. Any idea what's causing this? I've attached the link to the model.
Any help much appreciated. Thanks in advance.
Hey @HMoit, I think you forgot to share the link but I'm happy to help once you get that posted!
Almost. Forum bug. You have to wait for a moment or two before hitting post for the link to work.
Engineering textbook: https://hwh.stephenteacher.com/txtbook.html0 -
It appears not only Onshape is a big learning curve lol
In addition to the number of bends, I just reworked the flange sketches so that the patterned holes remain at the midpoint of the flange when I change the diameter of one the circles. Which has created a cutout in the platform when extruding its sketch. It didn't do so before - any idea why it does now?
1
