I have hexagon. I want to increase it's diameter from 11.75" to 23.5", How do I do that?
matthew_swain681
Member Posts: 2 ✭
Hello Mathew. Have you tried redimensioning it? - Scotty
If you created said hexagon with the Onshape hexagon tool, there should be an inscribed or circumscribed circle you could dimension to drive your hexagon.
If you sketched it manually, and it is fully constrained, you could just update the dimension of say one side or whatever the constrains are.
