Hole function merges two parts together, cutlist is no longer correct.
How can I make holes using one sketch?
Can you share your document?
you acn make hole with one sketch but can you explain more?
micah Lemaster/robot engineer
If you make a hole in a frame part that frame part changes and is no longer identical to other frame parts. The cutlist shows that.
Solution is to make a cutlist before I use the hole function. But there are other problems then. The merging does not work as expected.
https://cad.onshape.com/documents/e56f86a613d4f12c0bc71a91/w/722ee25324a020cefec15d49/e/501feb2e58e4329185f57e910 -
@sjaak_dirksen122 custom group override is one of the reasons I made a custom tool for weldments called Cut List Pro. You can request a free trial of it here.
James P. Miller
Mechanical Design | Custom Automation | Onshape CAD
https://millerdesignservices.net0 -
It sounds like the hole function is combining the two parts in a way that causes the cut list to become inaccurate. It may be worth checking the function settings and how the merged geometry is being handled to see if there’s a way to preserve the correct cut list. Barkingo
@sjaak_dirksen122 here's a copy of your document with an example of Cut List Pro combining four of the posts that Cut List wasn't grouping. I had to manually enter the material since it couldn't access your custom frames.
James P. Miller
