Struggling to Merge parts
Can someone please help me merge parts? Ive tried everything the internet has thrown at me. There was an error displaying this embed.
  • robert_scott_jr_
    Hey Brian. Welcome to Onshape. Can't really give you definite solution to your problem since it can only be guessed as to what the problem actually is. The best I can guess is that you want to use the Boolean tool but that'll only work if the parts are contacting each other. The best advice could be given if we could see what's going on within your build. That can happen, if you are able, when you put a link to your document when you post. That's usually necessary when it's about a specific problem. - Scotty
