One leader line leaves gap when releasing dimension.
tim_vandenbrink
Member Posts: 6 ✭
First image is while holding the mouse button to adjust placement, second image is after releasing the mouse. I don't really care if it's either broken or solid, though I'd prefer solid, I just want them to be the same either way. Help?
not sure!
can you side step the issue by not putting the dim inside the part and have a dia call out to the side?
Engineering textbook: https://hwh.stephenteacher.com/txtbook.html0 -
It does the same thing whether the arrows are inside or outside.
You can right click on the dimension and "unbreak" the leaders if you prefer.
1 -
That works, thank you!
