please give me step to step instructions on how to make a pulley
luna_serratos
Member Posts: 2 ✭
ai slop much?
When I was in school, I found that I learned a lot more when I did my own work. It doesn't make any sense to go to a class where you're not interested in learning things.
3 -
here are some step by step instructions that will teach you how to Onshape.
You can make a pully system with a few sketches, a revolve, and an extrude or two:
- Create a master sketch of your pully path
- Sketch the wheel profiles
- Revolve the profiles
- Sketch the harnesses
- Extrude the harnesses
- Sketch the spacers
- Extrude the spacers
- Insert all parts into an assembly
- Insert standard content bolts and nuts into the assembly
- Mate all parts together with the mate features
▚▞▚▞▚▞▚▞▚0 -
What do you mean?
