Support for niche thread diameters/pitches
andrew_tice
andrew_tice Member Posts: 1 EDU
I'm trying to model a component that has an M1.7 thread, but there's no option for that in the hole tool. Is there a way to input a custom thread diameter? I know that I can modify the diameter and tap drill diameter after that, but I mostly care that the callout is correct so that the correct screw diameter is used during assembly.
